yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
2010. New to me vector LTX GT . Bought with 900 miles during the riding season.
Now I pulled the skid out.......WOW..problem!
The control rod was unscrewed and the internal rod bent down so the outside aluminum housing is rubbing the track .....each bar is scuffed through so you can see the fiberglass rods. No problem with the rods just no longer covered with rubber for 1+ inch.
I was able to clean up the threads on the outside aluminum housing so it will screw in and out....not the smoothest but works.
But despite straightening the internal rod it does not want to slide easily in and out. I notice there is a seal over the rod so tight fit likely needed.
So enough venting the Question is were can I find this rod I can't seem to get the search to work for this. Yamaha wants 93 $ .
I am thinking
1. Buy used... Can't find yet
2. Continue to putz maybe emery cloth away the old until it slides easy but fear will leave a poor seal...get moisture.....ice and poor function and finally have to replace it any way.
So wanted to warn you all to check for the transfer control rod being loose and ask for help or guidance
I am thinking
yamadoo
- Jun 3, 2003
I found in the classifieds a couple of names to ask
If you know anyone with the control rod for 2010 Vector LTX GT let me know
thanks
thanks
thrasher
- Nov 22, 2006
- Ottawa Valley, Ontario
- 06 Vector RS ER
If you can still move the rod in and out by hand at all, still would be fine on your sled as it generates a whole lot of leverage on this part to move that shaft. Had to replace mine last year when the lower mounting bolt failed and screwed up the transfer rod. Had 23,000 kms on my skid frame and it was done also. Bought an entire rear skidframe in excellent condition for the same price that Yamaha wanted for just the weight transfer rod set-up. It's an expensive part, however, you just need one piece of it.
yamadoo
- Jun 3, 2003
Thanks I agree completely.
My buddy is very good at truing up shafts is going to give me a hand. Hopefully Can make it work
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
http://www.totallyamaha.com/snowmobiles ... ervice.pdfyamadoo said:Thanks I agree completely.
yamadoo
- Jun 3, 2003
I got it out. Fixed the threads so housing can screw together and apart to set transfer and with patience trued and sanded the rod so it slides in/out put it back together than in skid!!!!!
I believe she is good to GO!! Patience and success thanks guys
