BoostedNytoMC
- Jan 29, 2014
Drained the old coolant and added some new coolant. Just wondering on how to bleed the system. I have let it run on my tilt bed trailer and had the front of the sled lowered and then lifted to try and get air out. Not sure if that totally worked. Any info would be greatly appreciated.
1975FA
lift the right front side and remove the radiator cap. Let it idle till no more bubbles come out.
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
Running it through a couple heat cycles and topping it off when cold is all you need to do. These engines tend to purge air on their own so it's not a complicated procedure.
