rosco
2006 Apex GT. It ran great all last season with no issues relating to coolant levels. I just finished doing some preseason mtce including exhaust doughnuts. I noticed while workin on the doughnuts that I had some coolant poolling in the area where the solid tubing goes into the top of the valve cover on theright hand side. I am wondering if anyone has had a similar situation. I am thinking it could possibly be related to the O ring item 3 in the schematic. If it is I hope that I can remove the tube from the valve cover and replace it without introducing any coolant to the oil system. This looks like it could be possible because the valve cover gasket has a sealing surface that surounds the tube aswell as a seperate section that surrounds the spark plug
Any input is appreciated. I am goig to try and attach some pictures of the are as well as the parts schematic.
