olivia317
- Jan 20, 2013
- Olivia, MN
- 2012 FX Nytro XTX SC
NY AttakGT
Bump to the top for you...and me even though the post is about a year old with no responses. This is EXACTLY where mine is leaking but it is a 2007 AttakGT. Did you ever get it figured out? I was thinking maybe there was an O-ring at the joint were the metal pipe joins the water pump housing, which is secured in place with that
olivia317
- Jan 20, 2013
- Olivia, MN
Bad news, it's the water pump. The weep hole is directly above. Major job! Motor has to come out. Did it last spring and now I'm doing it again. As long as the leak is slow it's more of nuisance than a problem. Started doing it again this winter. Went through a quart of antifreeze in 20 miles, so I put in another seal. Not fun.
NY AttakGT
Thanks. I assumed whatever it was wasn't going to be easy since related to water pump and engine would have to be pulled. So does the weep-hole on the water pump have a seal that went bad? Or is the seal between where the joint and the water pump housing meet?Bad news, it's the water pump. The weep hole is directly above. Major job! Motor has to come out. Did it last spring and now I'm doing it again. As long as the leak is slow it's more of nuisance than a problem. Started doing it again this winter. Went through a quart of antifreeze in 20 miles, so I put in another seal. Not fun.
olivia317
- Jan 20, 2013
- Olivia, MN
It's more than likely the mechanical seal in the pump. everything else is sealed by o rings. You won't know until you get it out. I've got pictures but for the life of me, I can't ever get them to upload. Get a service manual, oil pan has to come off. You're going in deep. Dealer tells me it's a 5.2 hour job. I'm pretty sharp, 2 full days minimum.
NY AttakGT
Thanks. I'm fine with doing the repair, yanking the motor, etc... Tried some stop-leak but didn't seem to quick fix it to get me through season. I will leave it as a spring or summer project as I know there is no real quick fix. i saw oil pan had to come off as it is the same shaft the drives the water pump. Thanks for the info. i have to imagine that is MUCH more than a 5.2 hr job for a stealer.....err, I mean dealer.It's more than likely the mechanical seal in the pump. everything else is sealed by o rings. You won't know until you get it out. I've got pictures but for the life of me, I can't ever get them to upload. Get a service manual, oil pan has to come off. You're going in deep. Dealer tells me it's a 5.2 hour job. I'm pretty sharp, 2 full days minimum.
