Apex short track
- Jan 20, 2020
- Manitoba
- 09 Yamaha Apex
I would like to put a temp guage on my apex but I am wondering where to get 12 volt power from. I can’t hook to the battery or booster cables because they have power all the time and it would kill my battery. Can anyone help?
rustinpeace
- Sep 7, 2019
- Antioch il
- 2007 YAMAHA ATTAK
i picked up a digital temp gauge from summit racing. 2in diameter. take a hole saw and bore a 2in hole in your pad middle of handle bars(take off first,watch your fingers). wire into your fus box on fused side of headlight fuse(run sled w fuse out first= use the terminal that has no power w fuse out) strip wire and wrap around fused side of fuse and reinstall. the hose adapter cam get off amazon with a 1/8 in npt threads for temp sensor. i think its 26mm. search this forum for digital temp gauge and should see how it turns out(thats where i got the idea)
rustinpeace
- Sep 7, 2019
- Antioch il
- 2007 YAMAHA ATTAK
https://ty4stroke.com/threads/pics-...ffect-riser-12-apex.106952/page-2#post-982212
post#28 in the thread is what mine looks like also
Apex short track
- Jan 20, 2020
- Manitoba
- 09 Yamaha Apex
Thanshttps://ty4stroke.com/threads/pics-...ffect-riser-12-apex.106952/page-2#post-982212
Apex short track
- Jan 20, 2020
- Manitoba
- 09 Yamaha Apex
Thanks I meanThans
rustinpeace
- Sep 7, 2019
- Antioch il
- 2007 YAMAHA ATTAK
https://www.amazon.com/PitVisit-Tem...ords=26mm+water+adapter&qid=1582506176&sr=8-9
26mm adapter on amazon 10 bucks
also most sensors need to be grounded . will have to run a ground from frame to the little screw on the sensor adapter or the gauge will always read LO........(note it will read LO for a cpl minutes while sled gets up to about 75deg. then will show temps)
Apex short track
- Jan 20, 2020
- Manitoba
- 09 Yamaha Apex
I have a full kit with metal pipe and sensor and wires I just didn’t know where to steal power from.https://www.amazon.com/PitVisit-Tem...ords=26mm+water+adapter&qid=1582506176&sr=8-9
rustinpeace
- Sep 7, 2019
- Antioch il
- 2007 YAMAHA ATTAK
ok in my first post is where i did. only power while running
