DakotaBlue
I finally got to ride yesterday. Put on about 60 miles. Riding up in Hancock/Houghton, MI. Should the coolant temp be in the 3/4 position on the bar display? Just wondering if she is running to hot. This is my first four stroke and just wanted to ask the question.
Yamacat21
Set your display to read actual temp by pressing and holding the temp button then you can see actual readings. Mine runs 162-167 on the trail and will jump to 190-195 at idle.
Cc440
- Sep 8, 2013
- Rochester, NY
- 2014 viper LTX se
I have about 140 miles in mine. Temp reads around 160 to 165 degrees while riding. The temp does climb at idle and the fan kicks on around 190. Not sure where exactly that is on the bar
yamyfreak
Which button is the temp button??
Buckeye Rider
- Sep 21, 2013
- Oak Harbor, OH
- 2022 Sidewinder XTX-LE 146
2023 Sidewinder LTX-LE EPS
It should be then lower left button. Press and hold it and the number read out will appear in the bar.yamyfreak said:Which button is the temp button??
almond1000
- Jan 20, 2008
- North Fond du lac, Wi.
- 2017 sidewinder 2011 vector gt 2010 fx nytro 2009 vector gt
I believe you press and hold lower left button and it will show temp in the bar display
yamyfreak
I'll try that as soon as I get to the fuse box and get my gauge to work again.
