CPR Turbo Pics
BlueByYou2000
Staff member
Moderator
Sauk Prairie, WI
Website
www.ty4stroke.com
For anyone interested here you go:
CPR's Custom Header is designed to optimize exhaust gas pressure and temperature to the Turbo for maximum throttle response which virtually eliminates turbo lag, while retaining a high flow design.
CPR has designed thier intercooler to greatly reduce intake charge temperture with minimal pressure delivering you maximum potential horsepower. The intercooler on the CPR kit is the largest available. The cooler your charge temps, the more HP you make.
The Intake System is designed to optimize boost response time by not having excessive volume between the turbo, intercooler and engine. Less volume means less turbo lag.
This kit has been designed for the RX-1 with the target being mamimum trail reliability, instead of just maximum horsepower.[/b]
HERE GUY IS THE DYNO SHEET FOR THIS TURBO
Here you go. Dyno numbers, intake temp numbers, pre intercooled exhaust temps, pounds of boost, Horsepower and Torque
RPM=Engine RPM
TORQUE=Engine Torque in ft. lbs
HP=Horsepower
EX3=Pre Intercooled exhaust temperature
EX4=Intake temperature
Custom=Pounds of boost
RPM TORQUE HP EX3 EX4 Custom
5800 112.4 124.0 224 151 8.47
5900 113.0 127.0 225 151 8.43
6000 112.3 128.3 223 151 8.47
6100 113.4 131.6 223 153 8.38
6200 113.0 133.3 222 151 8.39
6300 113.1 135.8 220 154 8.28
6400 112.5 137.5 222 156 8.26
6500 111.8 138.3 223 154 8.25
6600 111.5 140.1 222 155 8.25
6700 112.0 142.8 221 156 8.18
6800 112.0 145.0 221 155 8.18
6900 112.1 147.5 221 154 8.18
7000 112.5 150.1 223 154 8.27
7100 112.8 152.5 226 155 8.23
7200 112.8 154.6 227 155 8.25
7300 112.5 156.5 226 152 8.13
7400 112.9 159.1 224 154 8.10
7500 112.5 160.6 225 153 8.06
7600 113.0 163.5 224 153 8.02
7700 112.0 164.3 227 154 8.06
7800 111.6 165.8 226 156 8.10
7900 110.6 166.5 224 155 8.13
8000 110.1 167.8 224 154 8.10
8100 108.5 167.5 224 155 8.05
8200 108.3 169.0 225 156 7.98
8300 107.0 169.1 227 154 7.96
8400 106.4 170.1 226 153 8.02
8500 107.1 173.5 226 154 8.02
8600 105.6 173.0 225 154 7.96
8700 105.5 174.8 224 153 7.90
8800 104.6 175.3 225 153 7.86
8900 104.1 176.6 225 155 7.86
9000 103.9 178.0 225 155 7.84
9100 103.5 179.3 225 154 7.78
9200 103.6 180.6 224 151 7.76
9400 103.3 184.8 226 150 7.75
9500 103.6 187.6 225 152 7.61
9600 103.3 188.8 225 151 7.61
9700 102.5 189.3 226 151 7.63
9800 102.8 191.8 225 152 7.67
9900 101.9 192.1 224 152 7.69
10000 100.8 192.0 225 152 7.65
10100 99.5 191.5 224 151 7.65
10200 98.0 190.3 224 152 7.57
10300 97.8 191.8 223 151 7.59
10400 96.3 190.8 224 152 7.61
10500 95.4 190.6 222 151 7.55
10600 93.1 188.1 221 149 7.50
10700 92.1 187.8 221 149 7.50
10800 90.9 187.0 220 149 7.51
These numbers are using PUMP gas, premium only. No race fuel added
TT,
there are similarities between the two of them. The routing is different to the intercooler, the header is alot different, intercooler is different and the plenum. They do look similar however. Did you ever find that Mounting template for that ZL skid for an RX1?...BBY
Belt and Template answer's
Sorry you don't like my belt It does look a little rough but it has over 300 hundred hard testing miles on it. I think I'll put a new one on this year. Now that I put piston's and did a little head work. The other question no I am in the Boat buss and have been realy swamped , I'll make a note to call and find out what happened. Greg (TURBO TURTLE)
turtle turbo, glad you like it, we worked hard on it, we tried to keep the underhood installation as clean as possible. with nothing laying over the engine, access to spark plugs is totally unrestricted. kit includes a new plastic fuel tank, the reason we went with plastic over aluminium is to prevent the possibility of condensation from building up in the tank, (water in gas can be bad) our kits are set to a 190 hp form when shipped, you can easily dial up more power with our adjustable wastgate if needed, but our target was to build the most trail reliable turbo on the market, (this is not to say other kits aren't trailable) (i think if a guy puts his mind to it anything can be broken) we just made durability our first concern, we were'nt interested in the power that the kit made on the first dyno run, instaed we focased on the sixth smokin hot back to back dyno run, (worst case senerio) you can see by the high intake temperatures listed on the dyno sheet that this was not a cold blast, on the first runs we didn't see much over 100 intake charge temps, but as the engine saturated with heat, run after run, we finally got it to max out with the data shown, were confident in knowing that we have developed our kit, for the purpose it was intended for. we didn't go for max hp, we didn't go for power at the expense of excessive noise, instead we opted for dependable, queit, trailable, pump gas, sustained hp, if this is what customers are looking for they should take a serious look at our rx-1 turbo kit. turbo turtle,you had inquired about selling my turbos, we are now taking orders on them, they cost 4500.00 us and require a 2500.00 deposit, delivery is 6-8 weeks from date of deposit. please contact me if interested. jeff
Turbo,
I don't think you understand... If you are who I think you are I meet you at the Syracuse/Cicero Asphalt race this past summer. I helped you adjust your track and cleaned your primary at the starting line. I had the TY shirt on and I was running a SRX.
--Buster696--
Buster, I think you have him mixed up with Supertuner? I think he made some 9 sec, runs this summer. I don't think Greg runs on asphalt.
