Woodysattack
Changed oil today and thought as long as I had everything apart I would check plugs. Plugs looked good but every end cap was loose what is the best way to stop this from happening I scored the threads but didn't seem to work. Any suggestions. Somebody said locktite but will this interfere with the conductivity. Any help appreciated. Thanks Woodysattack
heelingcowboy1
I crimped the ends of mine in a vice and then threaded them on
You can also buy plugs with permanent ends.Not sure what the designation is for them.
cmharcou
I put loctite on mine. I have started it up and I can't tell the difference. If conductivity is a factor I am sure not noticing it.
apltx08
Has anyone tried SODERING them on?
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
i used locktite only on base of threads,been fine.
I honestly dont see locktite hurting the conductivity,most times when i remove a bolt with blue on it you cannot even see it anymore.
Dan
Dan
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Tighten them on with a pliers, don't use lock-tight. I always tighten with pliers and they go no where. Not even when they deto and loosen the whole plug out of the head on a two-stroke!
