mshabaz
- Aug 16, 2006
06 apex, turn key, fuel pump cycles, eng cranks, check eng light flashes but wont start, will get hiccups as if it wants to start, then keeps cranking,,any ideas??
RTX
- Mar 31, 2005
- massachusetts / maine
- 2014 viper rtx
2006 apex rtx
Stator pickup.
Do you have a manual and an ohm meter?
If you do, its easy to check. If its out of spec thats your problem
TBay Sledhead
- Jan 16, 2005
- Thunder Bay, Ontario.Ca
- 06 Attak
01 SXR Long Track
Any codes?
mshabaz
- Aug 16, 2006
It's flashing something while I crank it. Is that indicating a code? And how do I enter the diag mode. This sled has been rock solid for 10k. Believe it or not. This is the very first issue
TBay Sledhead
- Jan 16, 2005
- 06 Attak
01 SXR Long Track
I see that you are a vip member. Request a manual from one of the admin's. all that info is in there. Go to the FAQ's at the top of this forum and look under error codes.
mshabaz
- Aug 16, 2006
Sounds good thank you
turbine tester
- Apr 8, 2011
- PEI Canada
- 2006 Attak
The code poped up on mine when mine went. I believe if may have been eleven for the crank sensor / stator assembly. Just try it and leave the key on and take a look at the display. Also check for chafed wires where the harness passes through the bulk head up by the voltage regulator.
turbine tester
- Apr 8, 2011
- PEI Canada
- 2006 Attak
Sorry code 12, also I would recommend an oem part if you need to. If you read through my below link you will see why.
http://www.ty4stroke.com/threads/attak-will-not-start-codes.110661/
ranger1
x2 on the OEM stator pickup as the R.M stator one needs the holes modified to have the right clearance, oem one is plug/bolt on & play
