crank no start, check eng light flashes
mshabaz
06 apex, turn key, fuel pump cycles, eng cranks, check eng light flashes but wont start, will get hiccups as if it wants to start, then keeps cranking,,any ideas??
Stator pickup.
Do you have a manual and an ohm meter?
If you do, its easy to check. If its out of spec thats your problem
It's flashing something while I crank it. Is that indicating a code? And how do I enter the diag mode. This sled has been rock solid for 10k. Believe it or not. This is the very first issue
I see that you are a vip member. Request a manual from one of the admin's. all that info is in there. Go to the FAQ's at the top of this forum and look under error codes.
The code poped up on mine when mine went. I believe if may have been eleven for the crank sensor / stator assembly. Just try it and leave the key on and take a look at the display. Also check for chafed wires where the harness passes through the bulk head up by the voltage regulator.
