Rappa
Went to a family party this weekend... We all get together once a year and bring the sleds. Lots of food, hanging out, and riding around my uncle's vast property. I had just taken the sled off the trailer when my sister asked to take it for a ride. I said "sure just be careful". I had to say hello to everyone and mingle for a bit anyways. Well about 20 minutes later she comes in the house with tears in her eyes and asked me to come outside with her. I said "Oh no..." She said "yeah". "I'm such an idiot" she said.
She was obviously alright health wise so I asked her "How bad is it?" "It's real bad" she said. I took the long ride to the other side of the property and there it was... My Attak GT with 900 miles on it kissing a tree. I braced for the worst, pulled it out of the woods with the help of my uncles and cousins, and inspected.
Well I was pleasantly surprised to see that she hit the tree just right. The hit was taken between the ski and the cowling. Not a scratch on the cowling and the Simmons ski was untouched. The Upper and lower control arms were bent back and broken at the welds. The Ohlins Shock seems a tad bent at the rod. But other than that, the machine seems fine. I was able to ride it back to the house and got it back on the trailer with ease. My sister was a mess thinking she destroyed my new sled, but I told her it can be fixed and it's not that bad!
So now here is my question... Since this will be the first time I need to actually buy parts for a Yamaha, where is the best place to go for the control arms? Is there a website that is recommended? Also, is there a way to fix the Ohlins Piggyback shock as opposed to replacing the entire shock? Maybe a rebuild? If so, who does that? Any info is greatly appreciated...
yamiboost
- Feb 17, 2008
- Labrador,
- 15 SR Viper MTX Hurricane 300hp kit
Fx Nytro Drag Sled 25psi + Boss Nos
Ebayyou can usually get some great deals on this stuff guys are removing it to add light weight parts and sell the takeoffs cheap.
nate007
- Dec 25, 2006
- Iowa City, Iowa
- 1. '06 Apex -twin screw
2. '04 Redline Revolt 800
3. '09 Nytro XTX - twin screw
dave_dj1
i got my new a-arms from PORT YAMAHA, great service and great prices!
Landoman
TY Member LANEO always has parts. Check in the classifieds for him.
Wisconsin
You should be able to replace the shock rod with a rebuild. the body is the most important part. I buy stuff on ebay....if you know what you're doing you can save a lot of money.
Crewchief47
- Jan 16, 2006
- McGregor, ON Canada
- 2008 Nytro MTX 45th
Rappa said:Also, is there a way to fix the Ohlins Piggyback shock as opposed to replacing the entire shock? Maybe a rebuild? If so, who does that? Any info is greatly appreciated...
I believe pioneer and hygear should be able to replace the shaft for you. If you send all of them in, including the rear, you may be very pleased with the results. If you need to get back on the snow ASAP, then a used shock may be the best answer. Then in the off season, you could send them all in and sell the used one.....or keep it for a spare.
64ssmax
Been there done that with the A-Arms last year. Dam trail markers just seem to jump out of no where!
I have a black 07 attak and yamaha only had red a-arms the black ones were on back order. so needless to say I was ripping the whole sled a part to powder coat the a- arms a black metalic. It ended up a blessing that I could only get a red set, because it forced me to take the whole front end a part. When I did that I called Allen @ Ulmer racing and installed his a-arm bushing kit.
I would strongly recommend doing so. My buddy has 4k miles and his are wore out now. Yamaha puts a nylon bearing in there and they do not last long.
Brian
Brian
Rappa
Thanks guys. I was able to order the parts I needed from Laneo and I also ordered the bushing kit from Ulmers. I was surprised how easy it was to take everything apart. The damage was limited to the a-Arms, bushings, and the shock. No bulkhead damage and Simmons ski is perfect. Not a scratch on the cowling either. She hit the tree perfect! Thanks again...
kotapug
Landoman said:TY Member LANEO always has parts. Check in the classifieds for him.
I got my parts from him and he is great to deal with and good pricing.Thanks LANEO
wth
Hey Rappa, Please look the bulkhead over very carefully. It may be cracked!
speedjunky
ebay first. Then try cheapcycleparts.com. Look your part numbers up on the Yamaha web site then go to cheapcycleparts.com and put the part numbers in. I have found that they are 40% less then that dealer, and you are getting OE parts.
