littleredsled
took my apex out of a ride the other day hit a rock at about ten km pretty slow and stopped me dead bent my a arms and my shock eye i took everything to the local welder shop and am getting him to bend everything back my question is with my shocks i got the ohlines and when i got him to straighten the eye do you think it will still work out we cant seem to see any bend or damage to the shaft and the top housing liek bends or anythgin will it be fine to still run the shock or am i gonna blow it out if there is the slightest curve in the shaft just wondering
LazyBastard
You need to measure the shaft to make sure it is straight. If it is bent at all, then it may grind at the seal, ultimately causing it to fail. The good news is that it won't fail in a way where it will snap off or anything, it will just leak out until you have no shock dampening. If the shaft is bent, then straightening it is still an option, but it will require some specialized equipment.
littleredsled
ya im just hopeing that it aint bent at all or else this will suck i just paid a few hundred bucks for the shocks and only got 250 k out of them
Crewchief47
- Jan 16, 2006
- McGregor, ON Canada
- 2008 Nytro MTX 45th
I would think the shafts can be replaced during a re-build at a much lower cost then replacing the whole thing.
Blue Dave
- Jan 7, 2008
- Ham Lake, MN
- '17 Sidewinder LTX DX
My buddy just bent the shaft on one of his Polaris front shocks and he had it rebuilt with the new shaft only adding about $25 USD to the cost of the rebuild.
He needed both front shocks rebuilt anyway so it worked out great. Both shocks rebuilt and bent shaft replaced all for less than the cost of a replacement shock!
SumpBuster
- Jul 18, 2003
- Carlisle, NY .
- 18 sidewinder; 06 Apex RTX
Probably best to get it rebuilt, but you can straighten them. A guy bent the shaft last year on Barnstormer's MXZ and we straightened it out within a few thousandths...some v blocks an indicator and a press. Still working fine with no leakage. But it wasn't real bad either.
TBay Sledhead
- Jan 16, 2005
- Thunder Bay, Ontario.Ca
- 06 Attak
01 SXR Long Track
If that is a KYB shock I don't think that you can buy a new shaft for it. Just had mine revalved by Shocktec and the shaft has some pit marks it. Brian told me that I would have to send the shaft out to be rechromed as you cannot buy parts for them.
