ApexEr07
I have a 2007 apex er with 13 mm sway bar, c and a pro skiis. Sled is awesome but skiis are to aggressive or cannot find right setup. has anyone tried the curve skiis. c and a's are white and in excellent condition make offer or trade
hondo
I have 1,500 miles on Curves and my brother has several hundred miles running Curves on his 06 Attak.
Absolutely awesome ski. They are an advertiser on the site.
They are extremely predictable and accurate. In my opinion they are one of best after-market investments one can make in the sport of snowmobiling.
Here is a thread to read as well as listen to the pod cast on how they work.
http://www.ty4stroke.com/viewtopic.php?t=61789
Snogoer gave them a grade of 9.3 out of 10. Snogoer didn't even use the recommended set-up. Much has been written about the skis.
Hope this helps!
Hope this helps!
which version of the C+A do you have? there are a few variations. what does the bottom look like?
ApexEr07
ADX
They are the adx
They are the adx
The adx as i understand are the longest, version and use a flat keel. There is just no getting around a long flat keel turning hard(but grabing great in a corner)
One thing that can help a little if you like the ski is to add spacers under the carbide.
Bergstrom skegs makes them.
they will make the ski more like the razor style with the center of the ski setting lower than the rest of the ski. On hard pack this will keep the long part of the ski out of the snow allowing it to turn easier
