Skydog
Well did not no where to post this but was thinking more of turbo guys and racers might know the best way to cut down a track. 2.5" to like a 1.5"
Thank you Skydog
Thank you Skydog
t_thall
knife dipped in 50/50 oil and gasoline
Snowman269
- Dec 2, 2004
- Baraga, MI
- 06' Apex
14' KTM 500 EXC "SnowBike" fitted w/ 15' Timbersled LT
07' Phazer
I used a utility knife and water. Now the Maverick is a 1.75 trail track, and hooks up hard. With the Turbo on real hardpack it will occasionally hook up and stand the sled on end. I have photos where just the rear wheels are all that's touching.
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Skydog said:Well did not no where to post this but was thinking more of turbo guys and racers might know the best way to cut down a track. 2.5" to like a 1.5"![]()
Thank you Skydog
Here is the easiest way, and it works so well, wears off all lugs perfectly and track stays in balance.
Find a nice piece of concrete side sidewalk next to a fire hydrant, hook the back bumper to the hydrant with a strap and pin the throttle. I doesn't take long!!!!! Like 30-45 seconds to take off half an inch depending on roughness of concrete slab. You could also tie it to the pickup on the flat surface on your concrete driveway.
I used to do this when it was legal to trim race tracks down to 1/2" lug height, prior to having to use the Camoplast race tracks with specified half inch lug heights with certain part numbers.
thinksnow
If you are serious about wearing them down, I could see this method working on stiff/short lug tracks, but not paddle tracks. I would think the paddles would fold over a little and wear down at an angle. You would loose the front edge of each gripping surface because of the wear.
Maybe raise the back of the sled so just a little of the track touches and go slow. Keep dropping the back down a little as it wears.
Snowman269
- Dec 2, 2004
- Baraga, MI
- 06' Apex
07' Phazer
I made a small jig to simplify accuracy, I had never cut a track beforeand I was concerned about the track being out of balance. Once I rode it it was smooth up to triple digits. But one day out in the boonies I ran across a road which looked the perfect surface to grind it down a little. So I punched it from a standstill and that ground them lugs exactly. But it did wear them angled, where the lugs were perfect for stopping, not a hole shot. So I gently put it in reverse and spun the track a few times v ery carefully. The lugs are quite thick at 1.75, so its not the perfect trail track, but the Maverick was junk to start with.
Capt.Caveman
Looks like the quickest with out doing a burnout after a sixpack
http://www.youtube.com/watch?v=IeCpl8Dh ... re=related
Snowman269
- Dec 2, 2004
- Baraga, MI
- 06' Apex
07' Phazer
Capt.Caveman said:Looks like the quickest with out doing a burnout after a sixpack
I'm SOLD, That is perfect! Thanks for sharing!
Capt.Caveman
No problem...not my idea, I would love to take credit but I can't.
I like the smokey burnout and a sixpack myself
But if you are looking for the cleanest job this looks like the way to do it in about 10 or 15 minutes and a 30 pack for you and your friends
Capt.Caveman
FLYBYU
