ski_bum
I've searched around and am looking for some more info before I take my grinder to the skid!
I am installing a backcountry track with wahl 9t extros, I know I have to cut 1/4 inch to 3/8 off the rails but I am curious how that will effect the sliders. Does anyone have any pictures of the job? What ever I cut off the rails I will have to shorten my sliders so they still screw into the rails?
Thanks!
Ski_Bum
Thanks!
Ski_Bum
Supa Dexta
What sled do you have?
ski_bum
I guess that would help, 09 nytro xtx.
yukon yamaha
- Jan 30, 2008
- WHITEHORSE, YUKON CANADA
- 2008 nytro custom! 2014 viper custom
hmmmm you should not have to cut anything off the rails.... the 1.75 back country should bolt right in after you take the tunnel protectors off
Ffbsy
xtx
yup just did the same mod, cut the rails shorter to clear the extro's, and cut the same amount off the front of the slide to make it fit.
Port-Parts
TY Advertiser
- Sep 18, 2003
- Port Washington Wi
- www.portyamaha.com
- 2012 Nytro RTX
2018 Sidewinder BTX SE
After modifying the rail we generally just take a dremel tool to the rail end cap before reinstalling it and take material away from the slide area side of the rail end cap so that stock slides will just bolt up without needing to cut them every time you replace them.
Sledguy89
Reading this makes me curious I'm in the process off extending my rtx to 136 an I have doo 9t drivers installed. Do I need to cut my rails to?
sorenson1610
- Dec 11, 2007
- Rothschild,WI
- www.contrx.com
Only the xtx models need the trim
BADSLED
- May 13, 2004
- Syracuse, NY
- 2012 Nytro MC Xpress 270
2011 Apex SE
2021 Sidewinder LTX SE - SOLD
Why don't you just install avid drivers and not worry about trimming..
Sledguy89
sorenson1610 said:Only the xtx models need the trim
That's good news haha
nitris223
- Nov 18, 2012
- Yorkton Saskatchewan
- Yamaha Nytro MTX
I installed the Yamaha extro's last year for a buddy and we never trimmed the rails. This must only be with Whals drivers. Did two XTX's with the back country and extro's.
ski_bum
Mod went really wel, went for the first ride today and man what a difference!!! Worth every penny!!
MNBlizzard
Just put the skid in with shocks and manually lift it up and down. If it hits then trim back accordingly. Should be able cut off the tip and reuse the plastic tip.
603NytroXTX
- Aug 19, 2012
- Salt Lake City
- 2009 Yamaha Nytro XTX
2010 Yamaha Apex LTX-GT
- Salt Lake City
Take the rail tips off and install Wahl Bros Anti stab through the hole in the skid where your your rail tips used to be riveted on. No trimming needed!!!
