upei93
- Apr 27, 2008
- Dalhousie, NB
- 2015 Viper X-TX LE MPI turbo
2009 Nytro XTX
I have been searching here and in the clutching section and can't find the info I'm looking for. I have an 09 xtx that I just put a pc3, excell header, plugs and filters on. I have D&F's running Turks set up with the filters and plugs and filters and everything was fine with 5 in the shoulder and one in the centre. Since I installed the header and pc3 I have added 2 washers to the centre and am still hitting the rev limiter. I know I saw a post about someone running the same set up but can't find it. Should I keep adding weight to the centre or should I add som weight to the tip? I would test but we don't have enough snow at home. Thanks for the help and happy new year!!
langow
Add a washer to the tip for sure. You do have the bolt there now, correct?
NsNyTro
yep i would add some weight to the Tip for sure, what are your secondary settings?
Turk
Tech Advisor
I have a set up using the black spring that works well.
bwwelke
I have the same set-up but I'm runing 2 washers in the center and 2 washers in the shoulder. It seems to work good for me
upei93
- Apr 27, 2008
- Dalhousie, NB
2009 Nytro XTX
langow said:Add a washer to the tip for sure. You do have the bolt there now, correct?
No bolt in the tip...
upei93
- Apr 27, 2008
- Dalhousie, NB
2009 Nytro XTX
bwwelke said:I have the same set-up but I'm runing 2 washers in the center and 2 washers in the shoulder. It seems to work good for me
Do you mean two washers in the tip??
upei93
- Apr 27, 2008
- Dalhousie, NB
2009 Nytro XTX
Turk said:I have a set up using the black spring that works well.
You have a pm...
bwwelke
Nope, the tip is empty, I tried all the combinations last year comparing it side by side against another sled. That seemed to work best for me.upei93 said:bwwelke said:I have the same set-up but I'm runing 2 washers in the center and 2 washers in the shoulder. It seems to work good for me
MOUNTY
Everyone on here can give you a good base line to start from with clutching. Until you can test in the area you ride or are going to do most of your riding a good baseline is all you are going to get, especially with DnFlies. I had to go to the store to find lighter bolts to fit/clear to dial her right in with teh kit you have.
Learning how to clutch yourself is worth a world of frustration. M2C
