fourload
Going with the Hurricane SM bundle cluster flash next week. I will be using the QAY 70 weights up front. Looking for a nice low engagement between 2700 and 3000. What spring do you guys recommend? Black/Red 48/120 or the red 40/133?
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
I run black/red -- 48/120
Dan
Dan
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
black / bronze for low easy engagement.....* wrong ...I meant red for low engagement
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
that is a higher engagement then stock, I didn't care at all for it.black / bronze for low easy engagement
Dan
WinterWolf
- Mar 25, 2017
- Connecticut
Sj you sold your Winder??? How come? Are you sled-less at the moment??
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
Dan
I stand corrected...red was what I meant at 40 kgs.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Ive been liking the bk/red alot for most of last yr, Helps keep top end RPMS in check. Before that I ran the bk/blue mostly but didn't like as much as this.I stand corrected...red was what I meant at 40 kgs.
Dan
chaleurphantom
- Oct 5, 2009
- Northern New Brunswick, Canada
- 2018 SIDEWINDER LTX-LE 50th Anniversary
2016 VIPER XTX LE - WHITE,
2009 VENTURE GT,
1995 POLARIS INDY 500,
1984 SKI-DOO CITATION 3500
Dan
What sort of engagement RPM was it at Dan? I bought one in a kit. I was using the Thunder Products Orange in the Primary. It has a very smooth, Low RPM engagement.
chaleurphantom
- Oct 5, 2009
2009 VENTURE GT,
From Dalton site;
Pre-load@ 2.888” Total force@ 1.593”
Dalton Black/Silver DPPS-B/S 41 kg 125 kg
Dalton Black/Red DPPS-B/R 48 kg 120 kg
Dalton Black/Blue DPPS-B/BL 53 kg 133 kg
Dalton Black/Green DPPS-B/G 62 kg 131 kg
Dalton Red DPPS-R 40 kg 133 kg
Dalton Orange DPPS-O 28kg 132kg
Dalton Black/Bronze DPPS-B/BZ 56kg 128kg*
Dalton Black/Teal DPPS-B/TL 72kg 142kg
* Note: As a reference, we tested a factory 2017 Sidewinder primary spring to be 57/115 at the above load intervals. Black/Bronze is a similar engagement to stock primary spring but a different more stable design. It does have a slightly higher compressed load.
Does any one know what the Thunder Products Orange Primary spring ratings are?
DTR 82-27
- Dec 22, 2006
- Drumbo, ON
- 2018 SIDEWINDER S-TX DX 137
According to Dalton’s website the black/bronze is a similar engagement to the stock spring but with a little higher compression. It says stock is 57/115 and this spring is 56/128. I got this spring with a clutch kit from TD and Ben confirmed this. I haven’t had a chance to ride it yet with the new clutch kit but that is what I’m hoping for.
Sorry, the post above came through same time I posted.
34pontiac
- Nov 16, 2014
- WI
- Sidewinder
Apex
Here it is in chart form.From Dalton site;
34pontiac
- Nov 16, 2014
- WI
- Sidewinder
Apex
35/126From Dalton site;
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Dan what do you like better about the blk/red vrs the blk/blue? Reason I ask,i have both daltons blue and green springs,the only time I ran his blk/gren was on grass,wanted higher engagement,but for trail riding I don't need or want a lot of engagement.Ive been liking the bk/red alot for most of last yr, Helps keep top end RPMS in check. Before that I ran the bk/blue mostly but didn't like as much as this.
Dan
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
already said....keeps rpms on top in check.
