rkkoeb
Bring it to a bodyshop if you want the paint to match up well. Hard to diy it if you are not familiar with body works.
You could also try and get a good used one from Barn of Parts.
darv
- Aug 9, 2005
- International Falls,minnesota
- 08 Apex 40th LTX
for what it going to cost it looks like the hood is off a apex call barn of parts and get a good used for $100.00 - 150.00 and call it a day it will cost you more to fix it.
RobX-1
- Coldwater, OH
I agree with darv in that you would probably be better off contacting @hibshman25 (Travis) of Barn of Parts and buy a good used one. For comparison, he listed a 2008 Apex 4oth hood @ $250 but suspect that's because it is a limited edition hood whereas other years might be around the price darv mentions. Of course, the only problem with getting a used one is having it match in color but I would not be surprised if Travis has what you are looking for or darn close it.
rkkoeb
I reached out to Travis and he is going to look and see if you has one
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
So I damaged my hood last year and want to repair the gouges in the hood. what is the best way to repair my hood? I already have color match paint but not sure how to go about filling in the gouges. Also is the finish semi gloss so I can match it
henseljg2 get in touch with him he has the best used Apex parts.
Augie
- Sep 2, 2016
- S.WI
- 98 700 VMAX
06 ATTAK
20 X2 XTR
21 RMAX2 LE
I have a blue one that is in perfect shape hanging in my garage you can have for $50 if you ever get close to the 53003 zip code
rkkoeb
I will reach out to him, thanks
mysledblows
- Jan 23, 2007
- Central MN
- Sidewinder, mcx phazer, phazer, apex
- Jenkins, MN
Is that the 06 color? If so I might have one hanging in the wall.
rkkoeb
The sled is a 09
RobX-1
- Coldwater, OH
It appears that color may have been used in other years where the only thing that was changed was the decals. The older years may match up where all you would need to do is order new decals. I saw some on ebay that were from an 06 Apex but the color appeared to be the same as what you had posted.
rkkoeb
I decided to give it a try and see how the repair will turn out
rkkoeb
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
What did you use to work the crack out - bond?
Looks good, nice job
MS
MS
rkkoeb
I went to Fleet farm and picked up a small tube of body filler and some primer for plastic. I took the hood over to a local auto store and had them match the paint (pretty close) and picked up a can of clear coat. The paint job doesn't look as deep as the factory job but for a rattle can I think it turn out pretty good.
Issue I did run into was when I went to wet sand the clear coat down a little my paint must of not been hard yet as I messed up the nose of the hood. I decided to let it completely dry and then sanded that part down again and repainted it. I should of taken a little more time between coats to let completely dry.
