scott boddie
- Dec 17, 2003
- braintree mass.
- 04 WARRIOR
i damaged my front heat exchanger with a rock getting between tunnel and track also ripped my track so bad i have to change it this sucks bad . i have 2 small rips on front exchanger any way to fix or do i have to replace also need help on how to replace track. does any body have used heat exchanger for sale i found track for $454.00 now i have to drill for studs the rock ripped track around 5 studs huge holes i was on back lake in pittsburg n.h. going 124 mph i cant beleve i didnt get killed with track so bad . i only noticed track was that bad when i stopped and track got stuck on plastic runners from not letting them cool down before stopping.
DC5
There is a new ripsaw for sale in the clasified section for $320 shipped. You can remove the heat exchanger and have it welded. Shoudn't be too expensive.
I would get it welded in the sled. drop the skid and pull the track. empty the collant. Other wise you have to pull the motor to get it out.
YamahaRx-Warrior
I have had my front heat exchanger out. You do not have to pull the engine. They replaced it for $250 was the cost of the part. Also got a new track for about $400. I tore a stud out and through the outter belt through the exchanger.
YamahaRx-Warrior
If it were to happen again I would weld it right in the sled. They charged 7 hours labor to take it apart change the exhanger, install a new track. The heat exhanger is also held in place from 29 rivits.
impalapower
I'd repair the exchanger if possible. Who knows when you'd wreck your next exchanger. Welding won't cost that much.
clharris
Get it welded I have done about 8 of them it is alot easier if it is out but can be done in the sled you want make sure you have no fuel in it , even take the carbs. off can't be to careful
sledheadgeorge
- Apr 28, 2003
- Which one? I have 6
If you can get it welded do it. Its a beeeeeach of a job to change one. Bin there done that.
sledheadgeorge
- Apr 28, 2003
If you can get it welded do it. Its a beeeeeach of a job to change one. Bin there done that. You don't have to take the motor out.
Sorry my bad I thought there were rivits under teh motor when I had mine out. I'd still get it welded
peakperf
- Oct 1, 2003
- Hayward Wisconsin
- 1972 GP292, 1972 GP433, 1972 GP643, 2003 RX1, 2007 Phazer GT
I just had mine welded in the sled. Track blew and 3 picks went into the exchanger. I just put an "Ice Claw" track on and will try that for awhile. I'll give a report on how that new track works.
Scott
Scott
