scotttruhart
- Jun 15, 2009
hi all, 06 vector gt got this season with 500 miles, i am finding the sled to basically go all over the trail. i have to always fight the steering it seems. it is totally stock and the previous owner used it on lakes ice fishing etc,, he was not a trail rider. i hear the skis need to be shimmed? i am thinking of getting some dooleys ? track is studdded, what size dooleys? any suggestions? i feel the sled is a lot of work to keep straight and im onlyu going like 30-35mph... would be dangerous to go faster i think like this. thanks
theCATman
- Feb 19, 2007
- WI
- Yamaha
Here is what I run on my Vec & Apex. http://www.johnmaster.net/Double_Down_R ... rd6808.htm
Best bang for the buck right here. Sold as a pair for the price, other brands are sold each.
This will cure 90% of your darting. The other 10% is in the setup of the suspension & I have a solution to that too.
http://www.ty4stroke.com/viewtopic.php? ... c&start=45
the kitchen
6" woody's dooly's work best for the vector.
turn the transfer rod all the way in to eliminate ski lift. some will say you will lose traction but the vector won't lose much.
Front shocks, top clicker turn all the way right and back 3 clicks
Bottom clicker turn all the way right and back 6.
Remote adjuster turn full hard and back 5 clicks.
Rear shock pre tension set to your weight.
Set your sled to these specks and the sled will turn right when you look right. STOCK SKIS!! Enjoy
mbw919
I'm very happy with my unstudded '06 Vector GT using 4.5" Deuce bars on stock skis, shimmed 1/8".
Crewchief47
- Jan 16, 2006
- McGregor, ON Canada
- 2008 Nytro MTX 45th
Please check the toe on the front end before you do anything else.
hossZ28
Still has a yamaha powerplant!
- Feb 6, 2009
- Ontario Canada
- 2014 Arctic Cat XF 7000 LTD
X2 you want a minium of 1/4 toe out at the front of the ski,sCrewchief47 said:Please check the toe on the front end before you do anything else.
Muskoka Man
SNOTRACKERS fix my Yammie after aftermarket skis , shapers , adjusting springs and shocks , Do yourself a favor and try them out
09nytro
yes check the toe i set my dads to 1/2 in. out works great and its all stock
scotttruhart
- Jun 15, 2009
vector
thanks all. i ordered the 6inch double down carbides from johnmaster , i am going to check toe when i install them. seems like a good thing to have the doubles either way on these sleds.
theCATman
- Feb 19, 2007
- WI
- Yamaha
Re: vector
You're gonna be very happy with these bars.
scotttruhart said:thanks all. i ordered the 6inch double down carbides from johnmaster , i am going to check toe when i install them. seems like a good thing to have the doubles either way on these sleds.
jamesc
take it from someone that just went through it, the difference is night and day
musselmark
I bought a used venture with 360 miles on it and it was doing the same thing. The manual says to have ~1/2" toe out and mine had 1/2" of toe in. I re-adjusted and it is great now.
RageX2
be careful with your double down bars. i had them and they did remove the darty nervous steering. however then it wouldn't go around corners. you may need to do more sled adjustments after installation. my DD bars are in the attic with all the other stuff i bought that didn't work. i now have pilot skis on all 3 our sleds and couldn't be happier. good luck
theCATman said:Here is what I run on my Vec & Apex. http://www.johnmaster.net/Double_Down_R ... rd6808.htm
What about the flex skis? I followed a girl on those yesterday. Down the straights she didn't even have to steer and around corners you'd swear she was on rails. She was enjoying her ride way more than me, and smoking me on corners. lots of bucks, but anyone use em?
