has any tried this mod? have an 06 apex wich i just picked up at the end of last season and was not able to get out on any trails, and have read that the skis are not the best for the darting problem. just wanted to know if this was good solution to this problem? thanks for any input.
i made a set for my rx1 using the stock skis and they work great. i switch between stockers and c and a skis and the stockers carve better. this year ill try simmons flex skis. buy a set you will be impressed with the handling.
Like their name says , the darting was gone. He uses hardex metal so the wear was very good, but the stock yammy carbides are junk, you'll need alot more carbide to turn. The dartless work for the darting though.
