shawnj
The accsy outlet(cig lighter type) on our Apex has no power. I checked and the wire is plugged in. Is there a fuse that runs this outlet only, as everything else seems fine. Thanks.
pat the rat
- Mar 13, 2006
yep,there's a fuse,its prob blown,i think its only a 3 or 4 amp
shawnj
Will check the fuse. Should of did this yesterday. Wife and I had to keep switching sleds to keep our shields clear. Brrrr
There is a 3 amp fuse that powers that circuit.Remove the right side cover. The fuse box is up high near where your right knee would be while sitting on the sled. I would replace it with a 5 amp fuse as the shields pull the max on the 3 amp.
fastdave
- Oct 20, 2011
- Chippewa Falls, WI
- 2007 Yamaha RS Vector GT
Is the fuse in the same place on a vector? My outlet is dead also.
Yes... pretty much the same. And yes, this is 3 amp too.
shawnj
Fuse it was. I only had a spare 4amp. Will pick up a spare 4 and 5 amp too. Thanks
