Kascade
- Jan 23, 2022
- PNW
- 2015 Viper MTX 162 SE
2016 Cat M8000 162 Ltd
I just had one of these (https://www.shopyamaha.com/product/details/srviper®-full-synthetic-oil-change-kit) delivered. On the box it doesn't specifically mention my model (2015 MTX 162 SE). The online description lists the MTX SE, but 2016.
Is there something unique with the 2015 MTX or is this just bad product description? I mean, it's the same engine...right?
murdered141
Snow Punisher
- Nov 24, 2015
- U.P Michigan
All the same, mtx has baffled oil tank and takes a bit over 4 quarts of oil
Kascade
- Jan 23, 2022
- PNW
Thanks much for the reply. My sled is due for it's initial change (was a 2015, but bought with only 397 miles). I'm stuck with just the 4 quarts that came with this kit. Getting another quart of the Yamaha specific oil will take me a bit. Think I am better off just using the 4 quarts for now (can't find in the specs how much "a bit over" 4 the sled actually takes, I must be blind...) or just top off with another synthetic 0w40?
ateick
- Mar 11, 2019
- '24 Rene XRS 900R
'18 SR Viper RTX (SOLD)
'20 Poo XCR 850 (SOLD)
I used this kit on my 2018 RTX this year. Didn't need any additonal oil. You should be good.
murdered141
Snow Punisher
- Nov 24, 2015
- U.P Michigan
Rtx doesn't have the bigger baffled oil tank so it takes just under 4 quartsI used this kit on my 2018 RTX this year. Didn't need any additonal oil. You should be good.
murdered141
Snow Punisher
- Nov 24, 2015
- U.P Michigan
You should be good on just 4 quarts, depends how you change your oil too, just look at the level on your dipstick, mine takes 4.3 quarts but I get my oil nice and hot, crack the breather in the valve cover , drain the tank, take out the bolt from bottom of motor next oil filter, then pull filter.Thanks much for the reply. My sled is due for it's initial change (was a 2015, but bought with only 397 miles). I'm stuck with just the 4 quarts that came with this kit. Getting another quart of the Yamaha specific oil will take me a bit. Think I am better off just using the 4 quarts for now (can't find in the specs how much "a bit over" 4 the sled actually takes, I must be blind...) or just top off with another synthetic 0w40?
Kascade
- Jan 23, 2022
- PNW
Mine seemed perfect with just the 4 quarts. It was the first ever oil change I've done on a snowmobile, and after riding for a couple of hours today the engine didn't blow up, so I'm pretty happy with that result. Manipulating the oil filter through that small access panel wasn't the easiest thing to do, I'll have to find a wrench with better clearance next time. Other than that, pretty straightforward though.
