Do extrovert drivers increase vibration?
shanksRX-1
Pennellville, NY
2010 Apex
LOCATION
Pennellville, NY
I have a 2010 apex this season which is very similar to my old 06. I notice more vibration especially under hard acceleration. Fells like it starts in the tunnel/foot well area and then in the handlebars. Nothing major just feels like more than my old Apex. The one difference is the 2010 has extrovert drivers. Could this be the source of the increased vibration?
It's possible, especially if the track is really loose.
How much free sag is there??
Many tunnel vibrations on Apexes are caused by a bad speedo side drive axle bearing.
It's possible but it's only got 1000 miles on it and when I pulled the seal to grease them they looked good.
Track is fairly tight, not as tight as I've run them in the past.
The vibration seems to clear up after about 60
my bet is on the bearing as well.
It was just the stupid belt. I should have checked that first but it only had about 800 miles on it. Previous owner must have smoked it. I slapped on a new belt and it's smooth as silk
LOL, i was just going n to mention check your belt for a flat spot. ;)!
Nice, easy fix. PO must have towed or got stuck and smoked that sucker. They're normally pretty bulletproof
