Do-nuts just about burned threw
turbine man
berlin wi. eagleriver wi.
Starting on next years project extending my appex gt to a 136, thought i would check my exhaust as so many of you are having problems. Pulled apart the pipes, found the do-nuts about 95% burned threw. This sled has about 4500 miles on it and was not leaking or backfiring. Seems like that s around the majic # for the starting of problems. Note the y-pipes look ok with no cracks or burned thew areas yet. Going to put new do-nuts in it and give it a try. I got to belive there are a ton of people out there going to have this same problem, wnen the miles start to pile up. Thanks ty people for all your posts on this subject, you guys are great. Jeff
Buddies 2006 Rage 5700 miles were burned thru too & no pipe damage. Looking at Yamaha 30 month emissions warranty to pay & will know more next week.
Not really sure I would say most of the exhaust goes toward the clutch side because thats more open. The rest maybe thru the tunnel out by the track. Havent really heard of any one smelling exhaust to much. my 2 cents Jeff
My 07ApexER is at the dealers now getting 4 new donuts and a Y-pipe, sled just turned 5000 miles.
Kaz
Kaz I hope your dealer is going to replace both y-pipes I got to belive if only one shows damage, the other will be wore thin a give you problems down the road. Last night i found my steering bushings the grease was all turned to dry almost power like in them starting steering hardner than normal ,one more 5000 mile duty. Jeff
