summitking
Do you need a adjustable blow off valve?
Skydog
I say yes!
summitking
bov
K then ill just spend the extra money and get it.
powderlites
- Sep 5, 2005
- Sicamous, BC Canada
- www.powderlites.com
Adjustible blowoff valve
NO !!
You need blowoff valve that is large flow and open at idle.
On carb models sleds you need to bleed boost off before carb float sense hose or tube.
EFI just needs one at air box to keep good throttle response and not to have sled wanting to run on after letting go of throttle.
Blowoff valves also help the life of turbo and keep turbo from stalling or trying to stop in a split second from 100,000 RPM!
Just my two Canadian cents worth!! But there getting worth more!!
Everyone have fun and when your fingers are frozen and ya gotta take a leak!! It is still small know matter how much boost!
NO !!
BlueMax
- Feb 18, 2006
powder
Where do you think is the correct place to monitor boost pressure?
powderlites
- Sep 5, 2005
boost gauge
Intake side! Vaccum/boost
BlueMax
- Feb 18, 2006
Between carb/throttle body and cylinder head?
Skydog
Yea i ment you need a BOV did not mean a adj. one.
Skydog
Skydog
summitking
bov
K well what brand of bov would you guys sugest? the one these guys recomend was a turbo smart adjustable bov but i dont really know what i need any sugestions on brand and model?
woodsrider
- Feb 17, 2005
- Lewiston, ID
- 2017 YZ450FX1 Moto-Trax 137 Mountain Kit
It depends on how big a turbo you plan on running. I use a Turbo XS and it seems to be working great (that is after I cut some coils off the spring so it would open at the least drop in throttle closure).
