treewhacker
I tried to call their #, it's not working.
Welcome
to the DynoTech Research sample page.
Below is a list of Articles available to our subscribers.
Click here to view a Sample
ARTICLES
(use your browser's 'find' command to search this index - Ctrl F in Explorer)
tuneUP article Arctic Cat F7 Firecat EXTREME TUNEUP!!!!!
airbox mods, Vforce3 reeds, aftermarket pipe, radical fuel flow adjustments, shocking HP improvements
2/28/2003
tuneup article ZR800 low buck tuneup continued....
dyno data from test number 006, aftermarket Ypipe with stock tuned pipe, which I forgot to include in the previous article.
2/25/2003
tuneup article ZR800 low-buck tuneup
jetting, airbox mods, Ypipe mod on Carl McQuillen's semi-stocker
2/22/2003
Kevin Cameron ROLE OF RPM
RPM, torque, BMEP, IntakeAirVelocity, 2cycleVS4cycle, portTimingVSvalves&camTiming, BoreVSstroke,
2/11/2003
article on RX1 H.P. the RX1 HP disparity from day 1 to day 2??
we discovered the cause of the missing RX1 HP!! ??
2/11/2003
article online Friday: RX1 sudden power gain mystery solved??
it happened again on a turbo RX1 while on the dyno-- lost airflow and HP, but we figured it out and got it back!!
2/5/2003
coming soon- on the dyno this month.....
cat F7 performance upgrades (dyno test scheduled for 2/17), 1100 HTG Ultra (done)
2/5/2003
'02 AmSnow Shootout "A view from the controls"
the 700's and Big Bores, dyno tested and piloted at the Shootout by DynoTech performance maven Sean Ray.
1/15/2003
02 AmSnow Shootout A View from the Controls
observations of American Snow Shootout dyno & field testing, small bore class by Sean Ray
12/30/2002
Pipe Shootout Update 2002 Polaris XC800 Twin Pipe Shootout
Twin Pipes from Aaen,CPI,HTG,PSI and SLP ....... Which would you buy???
12/22/2002
Now Here American Snowmobiler Shootout
dyno certification 12/2, 12/3 results posted now!
12/9/2002
2003 Polaris ProX 440 incredible single pipe HP!
the "mystery pushbutton" is the finest creation that Sean and Jim have invented yet! details inside!
11/18/2002
2003 YAMAHA RX1 TURBOCHARGED 2003 YAMAHA RX1
pumping air into the four-cycle engine to make more HP.
11/8/2002
Yamaha RX1 update... same sled, new day, more airflow and HP!?
you will be as surprised as we were!
11/1/2002
2003 Yamaha RX1 Stock Evaluation
Comments on the dyno performance of our first production RX1. SuperFlow 901 engine dyno, connected directly to RX1 engine output shaft
10/2/2002
Single Pipe Shootout 2002 Polaris XC800
Contributing editor Jim Czekala
6/29/2002
High Altitude High Altitude Observations
Contributing Editor Bill Davis-High Altitude Observations
2/1/2002
Old Forge Shoot-Out 2001 Old Forge Shoot-Out XII
Contributing Editor Sean Ray - Battle of Old Forge Shoot-Out XII December 2001 with Dyno Test Results
1/1/2002
Volume 7 Number 1 97 ZRT,Mach I,RMK,96 MXZ,680 SPX,Ultra
97zrt600PipeShootout,700Mach I & Race Imp,700 RMK,96 MXZ 670 Perf Imp,680 SPX/600BigBoreSPS,600ZRT,KCameronDetonation
3/1/1997
Volume 6 Number 6 Old Forge VI,600
Battle of Old Forge VI,600/800 Field Shootout/Dealer Prep,96 680 XCR SP,96 ZRT 600 Pipe Update,K Cameron-Detonation
4/1/1996
Volume 6 Number 5 96 Ultra,800 Storm,95 Mach I,96 MXZ 580
96 Ultra Pipe Update,95-96 800 Storm Comp,Turbocharged MXZ 670,V-Max 750 Twin,680 Ultra,95 Mach I Perf,96 SkiDoo MXZ 580,Formula III,KCameron-Airboxes
1/1/1996
Volume 6 Number 4 96 Ultra,95 XCR 600,Formula SLS,ZRT 600
96 Ultra Perf & Two Stroke,95 XCR 600 Pipe Shootout,96 SkiDoo Formula SLS,96 ZRT 600,Turbo V-Max 800 & XCR 600,KCameron-Oxygenated Fuels
5/1/1995
Volume 6 Number 3 Old Forge V,V-Max 600,580 ZR,Mach I & MXZ
Old Forge V,Gyt Kit - V-Max 600,Arctic Cat 580 ZR Shootout,95 SkiDoo Mach I & MXZ,V-Force Reeds - ZRT800,Mod Carb & Vaporation,KCameron-Suspensions
2/1/1995
Volume 6 Number 2 800 ZRT,Formula Z,440 XCR,SkiDoo MX/Mxz,V-max
95 Arctic Cat 800ZRT,94 SkiDoo Formula Z,95 Polaris 440 XCR,SkiDoo MX to MXZ,Decibels,Turbo V-Max 600,KCameron- Combustion
11/1/1994
Volume 6 Number1 V-Max 800,Thundercat,XCR 600,Storm,Mach Z
95 Yamaha V-Max 800,94 Thundercat Pipe Shootout,800 Storm & Mach Z Modifications,94 Polaris XCR 600 Stock Evaluation,KCameron-Suspensions
4/1/1994
Volume 5 Number 6 Old Forge IV,Indy XCR,Mach Z,V-Max 600
Old Forge IV,94 Indy XLT w/Triple Pipes,94 Mach Z w/Jawes Pipes,94 Yamaha V-Max 600,KCameron-Emissions Control & Two Stroke Engines
1/1/1994
Volume 5 Number 5 700 ZR,Indy XLT,Thundercat,580ZR,Formula Z
94 Arctic Cat 700ZR,94 Indy XLT-SLP Pipes & Trail Chambers,1000cc T-Cat,94 Arctic Cat 580ZR,94 Formula Z,Turbo Formula Z,KCameron-Torque & Horsepower
11/1/1993
Volume 5 Number 4 V-max 500 & 600,650 RXL & Mach I 670,94Storm
94 V-Max 500 & 600,Turbocharged 650 RXL & Mach I 670,200+ HP V-Max 4,Mach I 670 Perf Impro,94 Indy 800 Storm,KCameron-Clutching & Pipe Temperature
9/1/1993
Volume 5 Number 3 93 Exciter SX,Indy XLT,Turbo Wildcat 700
93 Exciter SX Pipe Shootout,Indy XLT Pipe Update,Turbo Wildcat 700,KCameron-Octane,Engine Cooling,Turbocharging & Fuel "Puddling"
5/1/1993
Volume 5 Number 2 93 Storm,V-Max 4,Phazer SX,A/C 550 EFi
93 Polaris Storm Perf Improvements,93 V-Max 4 Pipe Shootout,89 Yamaha Phazer SX Pipe Shootout,93 Arctic Cat 550 EFI,Dynometer Testing
3/1/1993
Volume 5 Number 1 Old Forge III,Shootout 580,650 & 750
Old Forge III,Dyno/Field Shootout 580,650 & 750,Arctic Cat T-Cat,92 AWS Wildcat Porting&PSI Pipes,KCameron-Transfer Port Design Turbo Indy 580 XLT
1/1/1993
Volume 4 Number 6 93 XLT,V-Max 4,Formula MX,550 EXT Spec,Mach I
93 XLT 580 Perf,93 V-Max4,SkiDoo Formula MX Perf,EXT Special 550 Pipe Update,Torsion Vib,Mach I 617 Turbo,Exciter II Turbo,KCameron-Carburetors
11/1/1992
Volume 4 Number 5 92 EXT,92 Formula Plus,Turbo V-Max
92 EXT Special Performance Improvements & Pipe Shoot-Out,92 Formula Plus X,ZR 500 Top End Kit,Turbocharged V-Max 4,KCameron-Heresy and Revolution
9/1/1992
Volume 4 Number 4 92 EXT,92 Formula Plus X,RZ 500,Turbo V-Max4
92 EXT Special Perf Improvements,EXT Stock & Mod Pipe Shootout,92 Formula Plus X, RZ 500 Top End Kit,Turbo V-Max 4,KCameron-Port Areas
7/1/1992
Volume 4 Number 3 93 Indy 583,Exciter II,V-Max 4,90Prowler 440
93 Polaris Indy 583XLT,91Exciter II Pipe Shootout,V-Max 4 Pressure & Carb,90 Prowler 440 Perf. Stock & Modified Shootout,KCameron-Combustion Mixtures
5/1/1992
Volume 4 Number 2 Old Forge II,Musclesled,Mach I,V-Max4,Indy
Battle of Old Forge II,Musclesled Shootout,92 Mach I-Perf,V-Max 4 Tuneup,Indy 500 EFI Pipe & Head Cut,700 Wildcat 91&92,V-Max 4 Carb Problems
3/1/1992
Volume 4 Number 1 92 Wildcat,Phazer,Mach IX,Carb Weights
92 Wildcat 700,Modified Yamaha Phazer,92 Mach IX,Stock 700 Wildcat Pipe Shootout,Carb Weights 87-90 Exciter,KCameron-Two Stroke Cooling Systems
1/1/1992
Volume 3 Number 6 91 V-Max,EXT,Mach I,92 Indy
91 V-Max 4,91 EXT Special,92 Polaris Indy 500EFI,Turbocharged Indy 500,91 Mach I, Mod 700 Wildcat,91 Indy 650 Pipe Update,KCameron-Combustion Chambers
11/1/1991
Volume 3 Number 5 91 Mach I,Yamaha&Indy,90 Arctic Cat,Exciter
Nitrous Inj 91 Mach I,91 Yamaha SRV Shootout,90 Arctic Cat Cougar,91 Indy 650 Pipe Update,PSI 650 Exciter Twin & 750 Polaris Triple,KCameron-Oil
9/1/1991
Volume 3 Number 4 Tech Issue,Air Density & Engine Performance
Tech Issue, Air Density & Eng. Performance,EFI & Pipe Temp,Engine Boring & Stroking,Machining a Stroked Two-Cycle Motor
7/1/1991
Volume 3 Number 3 91 Indy,I-500 Snowmobiles,V-Max 4,91 Mach IX
Mod 91 Indy 650,I-500 Cert-Polaris 400XC,Arctic Cat Prowler, Ski Doo MX-X,Yamaha SRV,91 Mach IX Shootout,V-Max 4,KCameron-Fuel Vaporixation & Per
5/1/1991
Volume 3 Number 2 Old Forge,90 Wildcat 650,86 V-Max,91 Indy
Battle of Old Forge,SLP Reeds & Trail Porting 650 Wildcat,86 Formula III V-Max,91 Indy 650 Carb,KCameron-Fuel Volatility & Performance
3/1/1991
Volume 3 Number 1 91 Exciter ,91 Mach I,91 EXT ,91 Indy,BMEP
91 Exciter II,Brake Mean Effective Pressure,91 Mach I,91 EXT Special,91 Indy 500 Stock & Pipe Update,KCameron-New V-Max 4
1/1/1991
Volume 2 Number 6 91 Wildcat,91 Indy,86 V-Max,Indy 500
91 Wildcat Carbureted 700,91 Indy 650 Carbureted,86 Ported V-Max updated,Excellent Engines,89 Mod Indy 500-SLP Pipes,KCameron-Tuning & Temp
11/1/1990
Volume 2 Number 5 91 Mach I,87 Yamaha V-Max,84 El Tigre,91 Indy
91 Mach I Prototype,87 Yamaha V-Max,84 El Tigre 6000,91 Indy 400,KCameron-Crankshafts
9/1/1990
Volume 2 Number 4 90 Middleweights,89 Wildcat,Turbo Indy 650
90 Middleweights-Indy 500 SP,Arctic Cat EXT Special,Formula Plus 500,89 Wildcat 650,Turbo Indy 650,KCameron-91 Yamaha 4 cyl
5/1/1990
Volume 2 Number 3 88 Wildcat,89 Indy 500,90 Polaris RXL,Exhaust
Stock 88 Wildcat Shootout, Modified 89 Indy 500 Shootout, Stock 90 Polaris RXL,KCameron-Making Two-Stroke Exhaust Systems
3/1/1990
Volume 2 Number 2 Phazer,Mach I,90 Arctic Cat Prowler,Nitrous
Modified Phazer Shootout,90 Arctic Cat Prowler,FIII Mach I Shootout,Nitrous Oxide,EFI Update,KCameron-Crankshaft Vibrations
1/1/1990
Volume 2 Number 1 89/90 Indy 650,89/90 Mach I,Indy 500,2-Stroke
89/90 Indy 650 Comparison,89/90 Mach I Comparison,89 Stock Indy 500,Thermal Coating,Compression Ratios,KCameron/Two-Stroke Engines
11/1/1989
Volume 1 Number 6 89 Mach I,89 El Tigre,Fuel Systems
89 Mach I Pipe Shootout & Tune Up,89 El Tigre 6000 Stock & Modified,Thermal Coating,Dyno Terms Refresher,KCameron-Fuel Systems & EFI
8/1/1989
Volume 1 Number 5 89 Mach I,Slick 50,Klotz Nitro,Indy 400
89 Mach I Modifications & Pipe Shootout,Dial-A-Jet,Slick 50 Treatment,Klotz Nitro Additive,Big Bore Indy 400/440,KCameron-Reading Pistons
4/1/1989
Volume 1 Number 4 89 Exciter, Formula Plus, Wildcat, Detonation
Ported Exciter,Bad Vibrations,Airbox Modification,89 Formula Plus,89 Wildcat Formula III,Wildcat Carbs,KCameron-Detonation
2/1/1989
Volume 1 Number 3 89 Wildcat 650, 89 Indy 650, 89 ArcticCat EXT
Stock & Modified 89 Wildcat 650, 89 Indy 650 Pipe Shootout, 89 Arctic Cat EXT,Brake Specific Fuel Consumption,KCameron-Variable Exhaust Timing
10/1/1988
Volume 1 Number 2 88 Phazer, 89 Mach I, 88 Formula Plus,89 Indy
88 Phazer pipe shootout, 89 Mach I, Modified 88 Formula Plus, Airflow, Stock 89 Indy 400 & 500,KCameron-Two Stroke Engines
5/1/1988
Volume 1 Number 1 88 Exciter, Formula Plus, Wildcat, 74 Mercury
Dyno Terms, 88 Exciter pipe shootout & PSI needles, Stock 88 Forluma Plus,Cold Air vs Hot Air-RAD, Stock 88 Wildcat 650, 74 Mercury 400 Snowtwister
1/1/1988
© 2001 Design and Hosting by Marchese Computer Products
Content © 2001 Dynotech Research
DynoTech
8 Apollo Drive
Batavia
NY 14020
phone
(585)345-0055
fax
(585)344-4897
email
Welcome
ARTICLES
2/28/2003
2/25/2003
2/22/2003
2/11/2003
2/11/2003
2/5/2003
2/5/2003
1/15/2003
12/30/2002
12/22/2002
12/9/2002
11/18/2002
11/8/2002
11/1/2002
10/2/2002
6/29/2002
2/1/2002
1/1/2002
3/1/1997
4/1/1996
1/1/1996
5/1/1995
2/1/1995
11/1/1994
4/1/1994
1/1/1994
11/1/1993
9/1/1993
5/1/1993
3/1/1993
1/1/1993
11/1/1992
9/1/1992
7/1/1992
5/1/1992
3/1/1992
1/1/1992
11/1/1991
9/1/1991
7/1/1991
5/1/1991
3/1/1991
1/1/1991
11/1/1990
9/1/1990
5/1/1990
3/1/1990
1/1/1990
11/1/1989
8/1/1989
4/1/1989
2/1/1989
10/1/1988
5/1/1988
1/1/1988
DynoTech
8 Apollo Drive
Batavia
NY 14020
phone
(585)345-0055
fax
(585)344-4897
POWERHAULIC
Yes I have been a subscriber since 1990, very good, accurate information. I have visited the dyno numerious times, had sleds tested also. 8)
treewhacker
Hey good buddy. Could you copy/paste the stuff on RX1 either here or to my Email? treewhacker@hotmail.com
