mmmkokanee
who sells the billet carb tees and carb caps and how much including shipping to saskatchewan?
I put about 40 miles on my bender stage 2 this weekend.
Running 135 mains and 17.5 pilots?(stock mountain rx1), screws 1 3/4 out, needles all the way up and now red cv springs. Running 6-7psi boost, stock engine, supreme fuel.
My innovate shows around 13 afr idling when warmed up, 14.5 to 16.5 at 8-9000 rpms (lean midrange at cruising, 50-60mph, even with the 2nd supply line from the intercooler to caps) and around 10 wot.
I did a pressure check and one tee bubbles a little and every time i took off the caps to raise the needles to try to get rid of the lean midrange they were wet with gas inside the cap.
So, I am assuming i need tees and caps!
Its still a blast to ride at even 6-7 psi right now...gets to 110 mph on the dreamometer real quick with the 151, 2 inch paddle and mountain gearing.
Thanks in advance
chris
Thanks in advance
chris
srxguy
Ted Jannetty does....
