maybe this is a stupid question but will 10 tooth drivers fit in the 03 rx1 mountian
whitee
no, I have a aftermarket tunnel with a rolled chaincase to make 9 tooth fit
i thought that stock in a mountian was 8 tooth and stock in a short track was 9 tooth
yamahaboy_15
i think that it might work but you would have to do alt of work it depends onthe sled i think.
i may have to drop and roll the chain case i need to try to get some pictures of it done any one got any
RXMax
How deep of track are you planning to run with your 10T drivers? Its going to take a tunnel and a drop & roll to clear 2" + track with 10T drivers? Or are you setting one up to drag race with a low profile track?
the max i will be runing will be a 1.25 smaller if i have to wat you think i will need to do both of it
RXMax
A drop and roll with an 1.25 track might give you the room you need to run 10T. Next question are you planning to run studs?
