drag123
- Feb 16, 2009
- Ottawa
- 08 fx nytro
I am intalling drag & fly clutch kit on my 08 fx nytro and they recomend the red primary spring but the thing has 2 extra coils on it how im i suppose to compress that long of a sping
? thanks in advance
upei93
- Apr 27, 2008
- Dalhousie, NB
- 2015 Viper X-TX LE MPI turbo
2009 Nytro XTX
Swearing a lot helps...get a friend to help you hold it down or buy longer bolts or make yourself a compresion tool. Watch the bushing when putting things back togeather.
justinator
- Mar 25, 2007
- Maine
- 2023 Arctic Cat Riot 9000
easiest way is to get a piece of threaded rod with some big washers and some nuts and pass it through the clutch and tighten the cover down. simple and no forcing at all..no swears
Turk
Tech Advisor
What also can be done if the cover bushing can slip over the clutch shaft bolt and washer. Is get some longer clutch cover bolts to suck the spring down. that way your not having to retorque the clutch bolt ever time
Otter
Otter
