1xr
I just puy some miles on these new ramps. I don't know the tuning purpose of the shoulder, is it mostly just engagemenr and low end? The overdrive, it is the absolute top end or is just an other spot to add tip weight?
I used the instructions with the kit shoulder 3.2, center 4.2, tip 3.2, overdrive 5.2 with the white long spring.
It does work good as far as I can tell from loose snow and being the years first ride, it's a little lower on rpm than before10500 falling to 10400. to gain 3-400 would i reduce the weight in the tip or the overdrive, or just switch it?
Turk
Tech Advisor
pm sent on set up
