saythey
What role does the OD position play on the weights. I would like to lower my rpm and get stronger mid range pull. When I wide open my rpm is 9000 then starts dropping to 8700. Should it not be 8700 and then climb to 9000???
Thanks for any help. PS does anyone have a manual that states what affect each position has when loaded or empty. I have been reading every post and trying to learn. This is all new to me.
Turk
Tech Advisor
How are your weights set up now ?
I only use od if I have tip & centre loaded & need to bring down rpm,s.
on a nytro low 8,000ish rpm,s climbing to 8900 is golden.
saythey
I am 4.7 heel and 5.2 centre and red spring
Turk
Tech Advisor
Add 1 more washer to heel. Will help a lot. part of the 9k take off rpm,s is spinning out plus your not loading the motor enuff.
saythey
I added one more washer and I still see that 8900 to 9000 every odd run. I will also see 9000 if I am doing 50mph and then hit it. It will rise to 9000 and drop to 8800 and climb a little to 8900. What is meant by motor is not loaded enuff. Do I start adding weight to the tip?
