2008 Nytro RTX
Will the service manual tell you how to replace this?
lucky_7
gormleyflyer2002 said:does anyone have the bearing number 62_ _) ? nice to have a spare.
The part number is SKU: 93306-20589-00
BEARING
apltx08
Here you go...you can get them from Royal check out the link its the 3rd 1 down on your left...but I noticed they have a note stating "not Phazer or Nytro" I tought we all used the same on 4 Strokes...I'd gine them a call to see.
http://www.royaldistributing.com/Shoppi ... 9/186.html
LJ 452
lucky_7 said:UPDATE: I checked both the drive shaft and the crank shaft bearings, and the drive shaft bearing was indeed bad! I looked exactly like the one in the pic on page 1.
The crank shaft bearing looked good.
That's "Jack Shaft" bearing not crankshaft. If we had to check the crankshaft bearing we'd be in trouble.
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
Do you mean the jackshaft bearing? Or chaincase bearings?
mryamaha
Its not a 62 number it was hard to match up at and aftermarket supplier, I would recommend just going to the dealer and sucking it up. I got one for my Attak a few years ago from an aftermarket supplier but the set screws were smaller, he tried for days to get an exact match and he couldn't. It was $20 cheaper than a Yammy one.
skyboz
LJ 452 said:lucky_7 said:UPDATE: I checked both the drive shaft and the crank shaft bearings, and the drive shaft bearing was indeed bad! I looked exactly like the one in the pic on page 1.
What's this "we" sh!t!!!
driftrunner
You might want to check your idler wheel bearings also mine were all rust with 800 miles on it.
lucky_7
Aha...both of mine were shot too!
So far, the annual replacement parts are:
-Both idler wheels
-Exhaust donuts/clamps
-Drive shaft bearing
-Both idler wheels
Unluckydiablo
We need a "yearly maintenance" post with the list of all things that need to be done before people ride for the year. Its hard keeping up with multiple posts when you might miss something. Also, all these little repairs/jobs we have to do, pretty much sucks when you don't have a garage (like me) to put it up in and work on it. Joys of riding I suppose.
lucky_7
Yeah, it would probably be a good idea for a sticky!
gormleyflyer2002
can we buy the bearnig loose or do we have to repalce the idler wheel also.....not near my machine to look.......?
