BigIron
- Dec 8, 2011
I have a 2006 Apex and its got a Team secondary and its got alot of play in the chain when its finger tight its got tons of slack and if i turn it with a wrench you can hardly turn it. Whats the call happy middle ground or just finger tight thanks
NY AttakGT
Finger tight and back off 1/4 turn then lock the jamb nut is the general rule of thumb.
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
NY AttakGT said:Finger tight and back off 1/4 turn then lock the jamb nut is the general rule of thumb.
X2
sk-rx1
If the sled has reverse you will always have that slack. Something to do with how reverse works. W/O rev, minimal slack.
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
Be sure to turn secondary clutch ccw to bring the slack to the adjuster then finger tight with 1/4 back off and yes there is supose to be some slack so it can go in and out of reverse
BigIron
- Dec 8, 2011
Thanks this is the first Yamaha it seems out of wack going from ski doo with electric reverse to mechanical thanks everyone.
"Be sure to turn secondary clutch ccw to bring the slack to the adjuster then finger tight with 1/4 back off and yes there is supose to be some slack so it can go in and out of reverse" thor452
What he said, you can also tug on the track to take up slack.
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
779cookies said:"Be sure to turn secondary clutch ccw to bring the slack to the adjuster then finger tight with 1/4 back off and yes there is supose to be some slack so it can go in and out of reverse" thor452
Never did mine that way but that is probably the best/most accurate way of checking/tightening the chain.
When you say finger tight, do you mean just tighten until you start to feel some light resistance or do you tighten it until you can no longer get it any tighter with your fingers?
Blue Dave
- Jan 7, 2008
- Ham Lake, MN
- '17 Sidewinder LTX DX
I have always "lightly" tightened the chain tensioner bolt with my fingers and then locked down the jam nut.
I was also surprised by how much back and forth rotational slop is present in the gearbox even after the slack is taken out of the chain.
sherlock29
the back and forth "slop" as people say is in the bottom gear. (2 gears in one) ... its for the reverse.. it is normal in these chain cases.
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
finger tight to me means as tight as i can get it with my fingers but that is also why i back it off 1/4 turn to tight and you can shear a shaft off.
