Driveshaft - be pro-active and replace before it breaks???
I was wondering the same thing, If I put in new driveshafts in my 05 RX1 and 06 Attak if the updated 09 shafts will work
Bob Miller said:
I wonder if the 09 Apex Driveshaft is stronger than previous models, and if it would fit? Something to consider! ANY FEEDBACK?
'09 nor '10 will NOT fit on '03 to '08, '09 won't fit on '10 either..., '09 & '10 are LONGER due to extra bearing in chaincase and '10 has same bearing set-up as '09 but LARGER diameter shaft...so I think YAM knows that they have a WEAKNESS at that level of the drive system! ;):D
COST TO REPLACE
DOES ANYONE KNOW THE COST IN LABOR TO CHANGE A FRONT DRIVE SHAFT AT THE DEALER? I REALIZE THAT THERE ARE DIFFERENT LABOR RATE SO WHAT IT THE BOOK TIME?
driveshaft drive it
06 rtx 15000miles drag race it speed run it pound it across rough frozen bays on second track 1st 12000miles 196 rotien 1.375 studs more worries donuts bushings wheels oil tank top shock wear stil best sled had dont rember them all now 07 gt 5800miles last year donuts wheels drive axel bearings changed every year drive it and have fun
Excellent Feedback! :Rockon:
Mine broke at about 5,000 miles, last half of those were studded miles. Broke between chaincase and driver. Remember, lose your shaft, lose your brakes. If mine would have broke two miles earlier, I probably wouldn't be in any shape to be typing this right now. I'd change it.
