daryl506
- Jun 2, 2010
Has anybody ever put drop brackets on a 136'' attack. like the mountain apex. i wonder how they would work? any ideas????
The top of the tunnel is meant to be close to level with the rider on the seat and normal suspension sag. Jacking up the rear can cause bottoming of the rear suspension arm before the front of the rear suspension has used its travel. The caster of the front suspension will be reduced affecting the steering. The spindles become more vertical and the steering less self centering.
daryl506
- Jun 2, 2010
So the handling will be gone. If I stretch it to a151" then lift it think it would be ok???
The handling will be different. You can decide if it is better or worse. I don't know of anyone who has gone that long, the monoshock may have geometry issues at that length, the rails bend at 136".
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
daryl506 said:So the handling will be gone. If I stretch it to a151" then lift it think it would be ok???
you will have alot of sled sitting on the skis. I would look for a skid from a mtx and mount it.
