apracing
- Feb 19, 2013
- new brunswick
- 2004 rx1 warrior 2006 apex gt 1979 enticer 340
i would like to get my sled sitting up higher in the rear , has anyone put drop brackets on there rx1 ?? i didnt want to change the way it handled and if i installed these does it make the track not perform rite ?? thks
Indy
I did it with mine, however I run a M10/136. The main reason was to have an easier job in removing the skid. Dropped about an inch, do not notice any difference.
tony tt
- Dec 24, 2012
I just happen to have a set for sale. These were on my 03 with a 136 conversion. I swapped in a 162" skid and it came with different brackets. I'll ship these no problem.
http://edmonton.kijiji.ca/c-cars-vehicl ... Z535124733
smokingcrater
Why do you want it higher in the rear? You are sacrificing performance for looks, as it does nothing for ability, but adds weight/pressure to the front.
RxThunder
smokingcrater said:Why do you want it higher in the rear? You are sacrificing performance for looks, as it does nothing for ability, but adds weight/pressure to the front.
X2!!
Indy
1 inch does not make a difference, and it is so much easier to remove the skid since the rear mount is no longer just inside the tunnel.
