Dropping my Apex ER at the dealer tomorrow
MXD
Boston, MA
He is replacing my boggie wheels with stock ones because he claims Yamaha has fixed the problem and it should be fine from here on out. He is also replacing the coolant with a 60/40 mix because I overheated all weekend on my maiden voyage (130 miles)
All I have done so far is set the sag in the rear. I have 144 picks, and 8in carbides. The sled pushes through corners and has way too much inside ski lift when it does bite. I'm going to try making some adjustments before my next ride to iron these issues out. Any suggestions are greatly appreciated as I have almost no idea where to start except with the transfer rod.
Check out all the other great posts on the susp. setup. Get these things adjusted to your liking and let me tell you........the thing will friggin' shock you how well it will rail!!!
What do you have for carbides?? get some good 6 or 8 inch carbides if you dont already!
Ive got over 1100 miles on my original boggys and still no problems..
Im bringen my Nytro back getten new idler wheels and a skid plate put on 1040miles on it toar apart.
