eboost2 electronic need help
Need for Speed 2
Nova Scotia
can anyone help, directions are clear to set up using a dyno but im field testing cant seem to figure how to get into sp1 to try and lower the boost limit. goes to 15 lbs in a split second but a little to much for pump gas. oh baby this thing has made my sled a blast to trail ride. i have instant boost on demand would recomend electronic controller for anyone trail riding.
Hey bud you have to put on sp1 then hold mode button down and then hit the down arrow it will then flash some letters. Letters means boost set for sp1. Hit the mode button 2 more times and a number will flash. 15lbs is around 45 or something. Just go up or down on that number and will change your boost for sp1 30 or so will be around 12. Then you can set all the others the same way. Then hit mode button again If i can remeber twice and it will say end and then its set. Not much directions come with them or mine didnt anyway.
