deshkae
For those of you running ECP filter setup
What are your settings on the Air screw and Carb needle position.
I see some are leaving the air screws stock and needles stock. Right now I have my air screws stock and needle raised one notch. I think it runs good but would like to get it close to perfect if possible.
DYNAREX
turn fuel screws out 2.5-30 turns and can leave needles stk #3
seems to be best for most and on dyno
Waterboy
Agree with Dynarex. Found a slight hesitation in mine so I raised the needles one clip. Tried it 2 clips first to get a drastic result and it was slightly rich.
Each sled may varry slightly and elevations will affect tuning.
