I just replaced the mid bulkhead and front left bulkhead on my 06 apex. how do I know where to adjust the motor mounts. Do I adjusted them to align the clutches. If so whats the best way to align the clutches with out a alignment tool. Could I take a straight edge across the back of the clutches to make them square. Hope this makes sence.
go on totallyamaha snowmobile tech page under clutching after engine relocation and you can take straigh edge from clutch and you need 15mm between straighedge and your driven
