pat the rat
- Mar 13, 2006
the engine braking on my 660 isnt working like it should be,when i let go of the gas it works for a bit then starts free rolling,if i give the throttle a shot it comes back on,anybody ever experience this
have you taken the clutches apart and re greased them??
vipeboy2000
- Jun 7, 2004
- Coalmont, TN
- Coalmont, TN
- WLM
- vipeboy2000@msn.com
- YAHOO
- vipeboy2003@yahoo.com
yea mine is doing that also.. just never had the time to take it apart or take it to the dealer..
pat the rat
- Mar 13, 2006
it was regreased last year and it was still doing it,someone mentioned to me about a 2 way bearing somewhere that let go on his and it was taking away is engine braking
frantzm67
- Mar 1, 2007
- Springville, Utah
- Springville, Utah
It is called a one way bearing and it is in your wet clutch. I just replaced mine and intalled a epi clutch kit at the same time. You will have to drain oil and remove crankcase cover to get to this wet clutch and bearing is right there. Mine was doing the same thing so I had already ordered clutch kit Mr sleds right regreasing primary will help also. but check that bearing. will need a new gasket for cover.
pat the rat
- Mar 13, 2006
oops,my mistake,one way bearing it is.is it a labour intensive job,ive taken the clutch apart but never went further,plus,how's youre clutch kit performing
frantzm67
- Mar 1, 2007
- Springville, Utah
- Springville, Utah
I put the oversize tire kit in mine even though I am still running 25 inch ITP m/s 589's and I do see a noticable difference. I am a big guy waying close to 380 lbs 6'6" tall and I pulled my first wheely in low. Scared me a little. wasnt expecting it. It is really simple job to change bearing you dont even have to pull wet clutch off unless you are changing springs on back side of clutch for kit. Then the only pain in the *#& is the nut that holds the wet clutch on has a detent on one side that will have to be straightened to remove. and you will have to be really careful with threads could get costly if not careful. You will need a clutch holding tool for the wet clutch because you will have to tork nut when putting back on. Rocky mountain atv sell one. or just make one like I did. if you plan on replacing bearing only then you dont have to mess with taking nut off just remove the housing cover and bearing is right there just make sure it goes on the right way. There are arrows etc.
pat the rat
- Mar 13, 2006
thanks alot,i will take it apart next week and change it,cant work on the bike on week ends cuz im ridingfrantzm67 said:I put the oversize tire kit in mine even though I am still running 25 inch ITP m/s 589's and I do see a noticable difference. I am a big guy waying close to 380 lbs 6'6" tall and I pulled my first wheely in low. Scared me a little. wasnt expecting it. It is really simple job to change bearing you dont even have to pull wet clutch off unless you are changing springs on back side of clutch for kit. Then the only pain in the *#& is the nut that holds the wet clutch on has a detent on one side that will have to be straightened to remove. and you will have to be really careful with threads could get costly if not careful. You will need a clutch holding tool for the wet clutch because you will have to tork nut when putting back on. Rocky mountain atv sell one. or just make one like I did. if you plan on replacing bearing only then you dont have to mess with taking nut off just remove the housing cover and bearing is right there just make sure it goes on the right way. There are arrows etc.
frantzm67
- Mar 1, 2007
- Springville, Utah
- Springville, Utah
Hey no problem any other questions I will try to help Its not bad to work on. MIght want to check on avaiability of bearing before tearing into machine. enjoy the ride
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
I am running the Highlifter kit, same as EPI and I love it. Best mod I have ever done to the grizz besides adding my 27" 589's.
I agree, it is your 1 way clutch bearing. Have you fixed it yet?.........Irv
pat the rat
- Mar 13, 2006
no,i will get to it before hunting season,im too busy using the bike and cant seem to get it in the shop,ah wellirv said:I am running the Highlifter kit, same as EPI and I love it. Best mod I have ever done to the grizz besides adding my 27" 589's.
