stephenpen
I plugged in the rb3 and now my sled will not start.
The check engine is flashing code 43. Fuel Voltage problem.
Any ideas.
When I unplug the unit it starts with no problems.
Any ideas.
yammi4ever
there is one plug that is the same style, and you can plug it in incorrectly. I cannot remember which one for sure, but take a look and maybe you can figure it out. If I remember correctly it it one of the triangle shaped 3 plug ones.
stephenpen
When I installed it the first time I plugged it into to wrong coupler. I plugged into the coolant temp sensor on the right side of the sled. It gave me a code for the temp sensor. I sent powderlites an email and they pointed me in the right direction, and I fixed it
The machine run fine when I put it on the trailer. Then we went to ride and it would not start. I unplugged the RB3 and it started. We rode without and it ran fine.
I tried plugging it back in and it will not start. I went over the entire harness to make sure it was not damaged. Still nothing.
If I can't figure it out I'll ship it back to powderlites to see if they can test it.
shadow44
call Dave @ Hurricane....I've never had any issues like that...other than making sure that the RB3 box is plugged in tight to the main harness I can't think of anything offhand that would cause that.
Pratas
the same problem at Venture Lite, what the fault is not clear: (
there are more ideas?
stephenpen
Pratas said:the same problem at Venture Lite, what the fault is not clear: (
did you figure yours out yet.
I'm going to ship mine out this week to have it tested.
stephenpen
I've been trying to get this to work and nothing. Now I get a code 12. I believe thats the crank position sensor. Its got to be a wire harness issue.
I don't understand how it started so many times without problems. Now this.
shadow44
Did everything check out with the RB3..you had it tested right? I think you're right about it being a wire harness issue....I've plugged my RB3 in several times and had no issues
stephenpen
shaddow44 said:Did everything check out with the RB3..you had it tested right? I think you're right about it being a wire harness issue....I've plugged my RB3 in several times and had no issues
I have not shipped it out yet. I keep looking at the harness trying to find something wrong. Its going out tomorrow to powderlites.
