Code 43
Labrador City newfoundland
I am getting code 43 sometimes on start up and the fuel pump wont kick in. I am wondering what could be causing this as my local shop cant figure it out. It only happens after the i have been out on the sled for couple hours and then shut it off and let it sit for awhile. code 43 is voltage problems to fuel system /fuel pump. Everything will come on gauges .. etc.. sled will crank but fuel pump wont kick in. If you leave the sled for about 8 hours and go out and turn the key she will start. ?? any suggestions?????
Had this problem with mine. Fuel pump went kapuut at the trailhead and ruined my day :o| Dealer pulled the fuel pump from my sled and tested it, but it was done ! They removed a brand new fuel pump from a still crated FX Nytro the same day and the rest was history, no more issues ever since.
I would also just check out your fuel injection fuse area to make sure everything is tight and no loose connections. Would be a pretty simple fix if something wasn't making proper contact here.
