yamahagirl
- Oct 30, 2003
- Upper Michigan
- www.boneymasonry.com
Any input before I get this thing to the dealer ... I am sure the dealer it out for at least a week or 2. Any heads up on things we can check in the mean time?
07 fx with blinking engine and warning light
We picked it up in Wisconsin and hauled it back to Michigan in the back of the truck with the rear elevated on the tailgate ... could this cause any problems?
gabe7924
You probably dumped oil from your tank into your airbox. Check your oil level.
barnstormer
Just a strech here but you didn't leave the key in for the ride in the on position? Because the fuel pump is to the very back of the tank under the seat. Possible you smoked it? Does the sled run? Give any error codes or the real simple hey stupid is if you have only one bar of fuel left the check engine will be on. May just need some gas.
yamahagirl
- Oct 30, 2003
- Upper Michigan
dropped it off at the dealer ... the key was not in the ignition
Thought about checking the airbox, but figured might as well let warranty cover it!
- 6K
