Engines not running smooth in low rpm:s
KnNil
Norrbotten, Sweden
Just bought a Venture lite and experience that the motor aint running smoothly just after the clutch engages.
At some times fault code 15 and 84 is flashing but if I turn off the engine and than starts again the fault codes disappear.
I think the wire to the T.O.R.S is unplugged by the dealer.
Whats the problem?
sorry if their is any languageproblems in the description. I am swedish soo :exc:
i´m learning!!
or the throttle needs to be adjusted.
anyone put on taller handlebars?
the sensor is sending mis-leading info to the computer. so the ecu is giving codes.
you could be right though.
disabling the tors wont throw a code 15. throttle position sensor, your cable may be to tight, or moisture in the throttle sensor. I just had a fried TPS, and it was constant code 15, yours is intermittent, so hopefully it is your throttle cable adjustment, try turning your skis from side to side when it is clear to see if it goes on.
so you mean that I might have to make my throttle cable "longer"? just so I know which way I have to adjust.
how much "slack" should it be on the throttle lever?
Kind of, if your throttle cable is adjusted to tight, it will be to high of a range for the throttle sensor. If you adjust it, count the number of turns you do on the adjuster, so you know your starting point, and can re-adjust back if it doesnt clear. Do a search and download the service manual, it will help you a lot.
update
The problem is still there and I found out that there is no coolant left in the container.
Connected the wire to TORS and I believe that it runs even worse.
Whats happening? where is the coolant go? ( can´t find any "spots" beneath the machine
