Indy
My local county fair is going all in this year. Full track go cart racing, atv and bike motocross, stock car race, truck & tractor pull, demolition derby and for the first time snowmobile drags on dirt. Very excited.
So the question is what do I need to do to my RX1/warrior?
" " " " 98 vmax dlx?
The RX is no longer studded, so am I waisting my time?
Indy
bump TTT
drop the front as far a possible, ditch the wear bars if they have any carbide on them at all and run it. that what i did with my nytro.
grass drag nytro
grass drag nytro
Indy
thanks.
ANYONE ELSE WITH SUGGESTIONS?
what about strapping down the suspension?
drop the gearing down, if its a short strip you want the sled running as fast as it can go, a lower ratio will make it faster off the line if you can make it hook
Indy
spddmon said:drop the gearing down, if its a short strip you want the sled running as fast as it can go, a lower ratio will make it faster off the line if you can make it hook
Already dropped gearing. What about strapping down the suspension? I've heard about this before.
sledheadgeorge
- Apr 28, 2003
- Which one? I have 6
If its not studded you're wasting your time. Grass drags are all about hook up. Install some chisels if you really want to hook up.
