Error code 13
Yamaha 64
Pembroke Ontario
I have a 2011 Apex SE and while driving the fuel indicator came on as well as error 13. Everything seems to be fine except for the error code 13. Anyone know why? Thanks.
Most likely you have a defective air sensor or ecu. Could also be a short circuit in the wire harness
Had this problem as well go to fuel rail area check two connections of the sensor type unplug then replug code should go away
