Griffin369
- Jan 4, 2015
- 08 phazer Rtx 136"
Ok on my
on my negative there are two wires plus the heated visor groundIf you look at the negative terminal on the battery there should be multiple separate wires connected there, I think three. If there is only the main wire then you don't have the kit.
If you post a picture of the battery connections I can probably tell.
Voda2000
- Nov 15, 2006
- Winnipeg Manitoba
- 2007 Phazer GT 136"
Are the two wires on a single lug?
Griffin369
- Jan 4, 2015
No three wires total. So it has had the update.. Talked to the mechanic at bb Yamaha and he said it sounded like a ground problem. I tried splicing a couple of the grounds from the yellow block back to the battery and no success.
ATV PRO #11
- Jan 22, 2011
- Garson, MB, CANADA
- 2014 Yamaha Phazer XTX
My issue drove me nuts.
Pry the grounding block out carefully and clean it up. There is a ground on the clutch side top panel that should be checked and lastly the ground in the ignition switch.
TO TEST: Take a scrap pc of wire, touch to grounding block and to frame or neg battery. Turn key and try to start.
Should do the trick. Splicing only a couple and not all will still point you in the wrong direction. One side of the block may have a lil black on it, Its usually on one side of the block.
Thats one of 3 main ground checks on these babies.
Griffin369
- Jan 4, 2015
Just went and tried that and nothing... It cranks a bit but not nearly enough to start. Same as before.
I started testing voltage and when I crank I'm only getting 9 v out of battery and 9 v going to starter. How much voltage drop is normal, this seems like alot.
ATV PRO #11
- Jan 22, 2011
Hmmm, not to familiar with loads on the Phazer. Did you try searching "starter"? Possible major draw?
Battery voltage full charge is: 12.6+
80% is 12.42v
60% is 12.2v
40% is 11.9v to give you an idea.
If your at 9v, you have a major draw aka starter (in my non prof opinion) And your killing the battery.
80% is 12.42v
60% is 12.2v
Griffin369
- Jan 4, 2015
Thats what im thinking too. It's such a pita to get at is it possible it's a system ground.? I just tried running jumper cables ( with booster pack) from the starter side of solenoid and to frame and it does the same thing
