Error Code 84
mcullin1
I am looking for information on Error Code 84.
2006 Apex GT is the sled. It started running rough and then would not idle on its own. Any ideas.
Thank you,
usually adjusting throttle cable, i did it on my RX i adjusted it so that there was just a little play in the cable, you do not want it tight, i think that some place in your book it tells how much play you need
you can bypass by unplugging the wires that go into the back of the throttle on the handle bars and connection the wires together, but do not leave it bypassed this is your tether
hope this helps
Gibby
This is for the FX Nytro but it should apply to your sled.
